Why am i running so rich? FPSS PROBLEM???
It sounds like you have a tunning issue. Are you adjusting your dedicated fuel pressure as a flowing fuel pressure or dead headed?
If you are just adjusting the fuel pressure by turning the pump on and turning the regulater screw until the gauge reads what you are looking for its called dead heading it.
You need to be using a flow check tool and adjusting the actual FLOWING fuel pressure.
A tool like one of these.
http://www.nitrousoutlet.com/catalog...el=108&dept=11
The small one is not certified.
Both will get the job done and come with a cross refrence chart and jets.
Dave
