injector size for a 150 shot
Old Apr 5, 2007 | 02:50 PM
BigD 275's Avatar
Default injector size for a 150 shot
I have a 99 Camaro with bolt-ons. I plan on getting the NX MAF kit and want to know what size injectors I should get. I plan on upgrading the fuel pump as well. Thanks in advance.
Old Apr 5, 2007 | 02:57 PM
N4cer's Avatar
Go wet so it won't matter.
Old Apr 5, 2007 | 03:00 PM
nahasapeemapetalon's Avatar
Agreed.
Old Apr 6, 2007 | 12:28 AM
Ben01C5's Avatar
What pump would you recommend him then? Walbro 255?
I would go 36-42 lb injectors for a 150 shot. I screwed up buying 30lb injectors. They will be tuned to your set-up, so might as well go bigger from the get go.
Old Apr 6, 2007 | 01:06 AM
koolrayz's Avatar
First of all the NX MAF kit is a wet kit so there is no need to go with bigger injectors. You stated you are going to upgrade the fuel pump, great idea do that and your good to go. There seems to be some confusion with some of you regarding the fact that the NX MAF kit IS a wet kit. Soooo the injectors are not adding the extra fuel, it is being added with the nitrous.
Old Apr 6, 2007 | 03:44 PM
Taubr Unit's Avatar
FYI, my buddy has the MAF kit on a 100 shot and it works AWSOME!
Old Apr 9, 2007 | 09:42 AM
BigD 275's Avatar
Thanks for the info.
Old Apr 9, 2007 | 09:47 AM
brad8266's Avatar
Old Apr 11, 2007 | 12:40 AM
98mysticZ's Avatar
i am running 42lbers svo green tops
