IAT wiring clarification..
http://home.comcast.net/~weaver.robe...timingpull.jpg
Looking at that diagram, I'm looking to use this relay:
http://www.dynotunenitrous.com/store...p?idproduct=47
I need clarification regarding the diagram. The diagram shows 5 connections to the relay, but the relay I listed above only has 4 prongs. Are the "87" and "87A" wires on the diagram connecting to the same prong on the relay?
Which wires on the IAT plug are the "A" and "B" wires in the diagram above?
What temperature range does the 750 ohm resistor trick the computer into thinking the incoming air is?
