Nozzle/Plate help needed
Old Apr 7, 2007 | 06:02 PM
BayAreaSS's Avatar
Default Nozzle/Plate help needed
ok.....i bought a used Nos single nozzle wet kit. It has a fogger nozzle and i found out that it is only good for 125 shot. I only plan on running a 100 shot but i know after i get comfortable with the spray i will probably work my way up to a 150 shot. Here are my questions....
1. Should i just buy a new single nozzle that is rated for a bigger hit? I just dont want to install my current nozzle and then have to replace it later. I would like to do it right the first time.
2. I have been looking at the plates and i really like them a lot! I would like to know if it is worth it to buy a plate instead of a new nozzle? I seen the vid of the HSW plate and it looks sick.
So what do you guys think?
Thanks
Old Apr 7, 2007 | 06:14 PM
Beer99C5's Avatar
You can convert to a plate system when you decide to upgrade, I think Nitro Daves conversion kit is $225 or so. Matt @ HSW is coming out with a plate as well. Not sure if the NOS plate can be bought as a "Conversion", shoot one of the Nitrous Outlet guys or Matt @ HSW a PM on what they have (or will have) available this season.
Old Apr 7, 2007 | 06:26 PM
Ping King's Avatar
you can buy the NOS plate as a conversion, but it doesnt come with any Throttle cable spacers or stuff like that.
Old Apr 7, 2007 | 07:15 PM
BayAreaSS's Avatar
I looked at nitro daves and it is 259.99(i think)
But do you think it is worth it to get rid of my nozzle for a plate?
Old Apr 7, 2007 | 07:39 PM
Beer99C5's Avatar
If what your doing now is working for you, I would stay with what you have. Being you already have the nozzle hole in the air duct, I would probably just upgrade the nozzle and jets when you go bigger.
Old Apr 7, 2007 | 08:39 PM
BayAreaSS's Avatar
See thats the thing......the kit is not installed yet.
It wont be installed for at least a month or two. I'm trying to get everything together first.
So thats why i'm thinking about getting a plate
Old Apr 7, 2007 | 09:17 PM
Beer99C5's Avatar
If its not installed yet I would do the plate.
I guess the major factor is what you want the final install to look like and what size shot your looking to support, as well as how much you want to spend.
Old Apr 7, 2007 | 09:30 PM
99Silverado5.3's Avatar
Old Apr 8, 2007 | 12:23 AM
BayAreaSS's Avatar
I want the install to be clean and i like the plate because i dont really like the hole in the bellow.
And i'm sure i will never spray over a 150 shot. Most of the time i will be spraying about a 100 shot. The plate just looks soooo much cleaner than a nozzle.
I like the way the HSW plate delivers.....i didnt see it on their site though. Maybe i'll just wait for the hsw plate to come out
Old Apr 9, 2007 | 12:41 AM
BayAreaSS's Avatar
anybody else?
Old Apr 9, 2007 | 01:10 AM
911ss's Avatar
hsw told me it would be out around end of march, hopefully soon but they offer no info when asked now....
Old Apr 9, 2007 | 01:55 AM
BayAreaSS's Avatar
Yea i searched it and didnt come up with a date. I'm sure it will be out by the time i'm ready to install my kit.
Old Apr 9, 2007 | 09:34 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
A plate kit will give you a much cleaner install over a nozzle, it will also give slightly better distribution due to having multiple distribution points.
You can get a different nozzle for ~$50 compared to $2-250 for a plate. At the 1-150hp power level will see almost no difference in power or distribution.
Old Apr 9, 2007 | 03:19 PM
BayAreaSS's Avatar
Yea i was looking at all the vendors different prices on nozzles and it seems like i should just get a new nozzle instead of the plate because its a lot cheaper. BUt the plate look sooo much better.
Damn....now i need to get info about different nozzles. I'm confused
I do know that my NOS fogger nozzle is not very good
Old Apr 9, 2007 | 04:04 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
a while back a member did a complete side by side test of all the nozzle's out there...the concensus was they were all close enough to each other in power made to not make that much difference. Any of the nozzles will make almost the same power.
What I would look for is on that will use the same style jets that you already have.
You will need one that uses NOS style jets, or you will need new jets also.
Old Apr 9, 2007 | 06:05 PM
BayAreaSS's Avatar
Yea i seen the nozzle shootout by Mrr23.
Do you happen to know what is the max shot i can use on the NOS fogger nozzle(black)??
If i dont have to buy a new nozzle i wont. I just thought the nos fogger could only handle a 125 shot
Old Apr 9, 2007 | 07:04 PM
99FRC's Avatar
I bought the ZEX kit and then Dave's plate came out prior to my install. I jumped all over that and never looked back!! Nozzle, Schmozzle!!!
Seriously, if it a clean install you're looking for, you don't want to go drilling holes in your air bridge or MAF or whatever, having to tap them for the threaded nozzle and worrying about nozzle placement, direction, etc. With a plate, you know it's done right.
Good luck!
99 FRC
Old Apr 10, 2007 | 03:34 PM
BayAreaSS's Avatar
Good luck!
99 FRC
Yea the plate looks a hell of a lot better than a nozzle. I guess i'll have to wait and see if my funds will allow me to buy a plate.
