150 shot + 44 degrees timing= octane
Old Apr 18, 2007 | 04:05 PM
fastlt1's Avatar
Default 150 shot + 44 degrees timing= octane
As the title states when running 150 shot wet and and 44 degrees timing at WOT what octane fuel needed? Thanks.
Old Apr 18, 2007 | 07:22 PM
daniel6718's Avatar
hmmm 44 sounds like A LOT...im guess like 275 octane...
im thinking you wanna be near 25-29 degrees and 93, or 28-33 with 110
Old Apr 18, 2007 | 07:32 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
boom
Old Apr 18, 2007 | 07:36 PM
Robert56's Avatar
How did you end up with 44 degrees of timing? Do you mean 24*? Don't even think about running timing of that degrees, keep it stock or a tad less, and you could run 92/93 octane, but nothing will save ya at 44*.
Robert
Old Apr 18, 2007 | 08:23 PM
fastlt1's Avatar
I think I was running 44 before n20 pcforless tune. Then I believe he pulled 5 degrees for 150 shot. At least spark advance shown by data master was 44 before and 39 now.
Old Apr 19, 2007 | 12:00 AM
BOTTLEFEDLS1Z's Avatar
BOOM!!!!
39 degrees is way to much.
Old Apr 19, 2007 | 12:13 AM
thebufenator's Avatar
LT1's have a farther advance
Old Apr 19, 2007 | 12:15 AM
I didn't even see that
Old Apr 19, 2007 | 01:19 AM
daniel6718's Avatar
my cam only motor was puchin it with the n/a tune at 38 degrees...you cant ahve more than 40...with the bottle like i said pull 8 for the 150...
Old Apr 19, 2007 | 08:00 PM
Robert56's Avatar
True, however, the range he wants to run will equal destruction, almost guranteed? Any body out there running any car with a 150 hit and 39* of timing?
Robert
Old Apr 19, 2007 | 08:15 PM
fastlt1's Avatar
Do you think a can of torco would be a good idea?
Old Apr 19, 2007 | 09:08 PM
daniel6718's Avatar
no you need to take out timing...like is said start at 25
if your running 44 now i bet you knock sensor is pulling about 8...so your really at about 36
Old Apr 20, 2007 | 03:27 PM
SS Blazer 07's Avatar
Default Timing
What you don't understand you will run fast with less timing. Nitrous make more HP & torque with less timing. About 4*-5* less for every 100 HP shot. It is also a good idea to use NX Nitrous octane booster as well. A lot of the octane boosters sold are crap & tune you plugs redish brown. Go down one plug heat range & gap at .35 also a colder thermostat is a plus. Always use a good adjustable bottle heater to stay at 1050 to 1100 psi before you purge leave at 1000 to 1050 psi. Don't try to run the bottle to low. A nice big nitrous canister filter is good insurance. Large hits below 3,000 could go boom. Two stage is easier on all the drive train & gets better traction netting faster time's using a delay timer with a 2.5 second delay for stage two. Fuel pressure gauge is a plus also a wide-band A/F
like (Innovate) run A/F at 11.5 to 11.8. The above will let you run lot's of bottles safe also you will run faster & more consistant. Don't do the above and you need to save up for all that will soon break.
I have been running nitrous for over 15 year with nothing blowing up on several auto & trucks. MSD has a nice new item called a Twister that pull's timing when you hit the nitrous & it's adjustable so you can run motor runs with your best tune & hit the nitrous & it pulls timing for you, LOL
Old Apr 23, 2007 | 09:14 PM
fastlt1's Avatar
Just got email from Bryan from 36 to 31. Would it be worth adding enough octane to gain the 5 degrees back?
Old Apr 24, 2007 | 07:41 PM
GueSS Who's Avatar
My roommate has been tunning LT1s with LT1edit for along time. He said that when he tunes them, no matter what the setup it doesn't get over 39 degrees. He said that the computer adds 1-3 degrees sometimes so he puts the timing allowed at 36 usually so it can't go any higher. My rule is 2 degrees per 50hp. I would run atleast 104.
Old Apr 24, 2007 | 07:51 PM
brad8266's Avatar
Why would you want 44 degrees, thats pointless?
