The juice & the boost...
Old Apr 19, 2007 | 08:20 PM
02SS:ZEUS's Avatar
Default The juice & the boost...
I getting ready to throw in my nitrous system. Its an NX wet kit, purge, heater, FJO controller, and Daves 85mm nitrous plate. I know that down the road I will be eventually going to a turbo motor....but I want to keep the nitrous. How effective would the nitrous be with boost. Will it help that I am using a plate system, rather than a nozzle?
Old Apr 26, 2007 | 09:40 PM
dirtdevil99's Avatar
Only thing I know for sure is that the nitrous will lower the temperature of the intake air causing a denser charge of air (same idea behind the intercooler).
Old Apr 27, 2007 | 07:11 PM
transamfreak01's Avatar
wiht the nitrous you can use it to spool the turbo when u get that far so i would keep it depending on how big you go but u can always use it when you want
Old Apr 27, 2007 | 08:48 PM
dpw41285's Avatar
keep it..a 50 shot will yield almost double that in hp. plus your motor will be buil so go for it.
