what size shot
Old Apr 23, 2007 | 10:56 AM
kackley's Avatar
Default what size shot
ok i have a 98 transam with 233/239 cam and texas speed head ...what would be a good shot to run on my car with out taking chance of damaging my motor ...i guess bacically what is the biggest shot u guys think i can run safely ..also what should i have my timing set at with that shot ....i just need that little extra help against a buddy of mine
Old Apr 23, 2007 | 09:41 PM
Dave00C5's Avatar
Put a 100 shot wet on and no worries at all.
Old Apr 23, 2007 | 09:52 PM
TwistedSS's Avatar
What fuel pump are you using? If it is stock, i'd consider upgrading before you spray.
Old Apr 25, 2007 | 08:50 PM
WE TODD DID's Avatar
At least a 500 shot.
Old Apr 25, 2007 | 08:55 PM
nickdotcom's Avatar
go big or go home
Old Apr 25, 2007 | 09:01 PM
transamfreak01's Avatar
get a new fuel pump and throw a 150 wet shot on there... ull be fine with no worries but i wouldnt go bigger than that
Old Apr 26, 2007 | 07:20 AM
slow trap's Avatar
i'd try a 100 shot first. that should really wake the bottom end up and still give you quite a bit stronger pull up top. i would be scared of a 150 shot with a stock bottom end with your mods,even though some have run that big or bigger of a shot with even more mods than you.
and as already said,if you haven't already upgraded the pump it would be wise to do so.
Old Apr 26, 2007 | 08:36 AM
john563's Avatar
dont mean to hijack this thread,but it may pertain to his question.I have a 98. Heads ,cam and fastintake in a stalled A4 and put down 417rwhp 407rwt,and was wondering the same thing,of how big i can safely go.Would we need rod bolts being that we are 98 or does that only pertain to large cam combos(i have a tr224 cam).
Old Apr 26, 2007 | 09:34 AM
kackley's Avatar
yeah i'm planning on upgrading the fuel pump before i spray on it ........thanks for the info guys ........
Old Apr 27, 2007 | 12:51 PM
502Stingray's Avatar
ehhh dont go 500 shot, Im running a 150 shot on my LS1, with no worries at all, I even have no detonation with 29 degrees adavnce, between 100 and 150, and cold plugs and proper precautions, N20 is super safe!
