need a diagram
Old Apr 23, 2007 | 10:22 PM
nickdotcom's Avatar
Default need a diagram
sorry to make a post but i posted in the sticky a few days ago but got nothing
i need a wiring diagram that includes single stage dynotune wet kit, WOT switch, purge, FPSS, and WS
i've been looking for this for a while, any help is appreciated
Old Apr 24, 2007 | 07:58 PM
nickdotcom's Avatar
well i guess im the only person using this setup, thats pretty amazing
Old Apr 24, 2007 | 08:25 PM
B.W.'s Avatar
Mine is almost identical to yours, I don't use a FPSS though.
If you have the dynotune style WS, just don't bother with the WOT switch as there is one integrated in the WS. On this drawing, there is a WOT switch in there, but just send the blue wire to the TPS signal wire on your throttlebody.
As far as the purge, I didn't integrate mine into the main system wiring. Just ground one wire, send the other one to a momentary switch and send the other prong on the momentary switch to your power source.
Old Apr 24, 2007 | 08:32 PM
nickdotcom's Avatar
thanks alot man, im getting prepared for this install
instead of going to the key ACC, could i go to the battery?
and the 25a is a fuse correct?
Old Apr 24, 2007 | 08:36 PM
B.W.'s Avatar
Mine came with a 25a fuse, I think some people might run a 30. I guess you could go to the battery, but why would you?
Old Apr 24, 2007 | 08:38 PM
nickdotcom's Avatar
seems like it would be easier to go to battery than key ACC, because i dont know were that is
Old Apr 24, 2007 | 08:45 PM
B.W.'s Avatar
The key ACC is terminal under the red plastic thing on the far right of this picture (don't mind the mess )
Or there is a pink wire that goes to the cig lighter in the center console that you can tap, it might be a different color so search don't quote me on that. I just had my solenoids mounted under the hood fusebox area so I just tapped the key ACC right there
Old Apr 24, 2007 | 09:33 PM
redbull396's Avatar
For the purge, do you need to put a fuse/relay in the wire from the switch to the purge noid?
Old Apr 24, 2007 | 10:10 PM
nickdotcom's Avatar
were exactly is the TPS signal wire on the throttlebody, and how would i go to the tach signal
Old Apr 25, 2007 | 09:50 AM
BOTTLEFEDLS1Z's Avatar
Why would you tap directly off the battery? All your gonna do is drain it.
The "little red thing" that was described above is constant power. You have a battery cable that runs directly to it. Take a voltmeter and with the key off, ground it and put the other probe on that spot and it will read constant voltage. Not a good spot to get switched 12v power. You can wire your relays to that spot because they need constant power.
The keyed ACC is on the driver side of the dash. Open your door and take off the black panel and you will see it.
Old Apr 25, 2007 | 02:15 PM
nickdotcom's Avatar
ok so relay goes to constant power
i opened my door and the only black panel i saw was covering the fuses, no key ACC
i also dont know were to get the tach signal, i think i've read the coild pakc will work somewere
Old Apr 25, 2007 | 05:36 PM
Ok, when you take off the panel, look at the diagram explaining what fuse is where and how big it is. Look for ACCY and thats the spot. A standard flat terminal spade will work for that spot.
On my 2000 its pin 10 on the PCM. Its a white wire. Just pull the bottom cover off the PCM and look for the number 10. There should be a white wire in that spot, but I'm not sure for a 02
Old Apr 25, 2007 | 05:53 PM
Nithros's Avatar
Yeah I used that IGN for one set of wires and spiced into the power window connection for an additional connection on my previous car (WS6) without any problems.
Old Apr 25, 2007 | 07:23 PM
nickdotcom's Avatar
do you have any pictures? or know were i might could find some?
Old Apr 25, 2007 | 07:34 PM
Danger731's Avatar
send me an email I can show you lots.
Old Apr 26, 2007 | 06:53 PM
Yeah send me your email and I'll show you how I wired my kit up...
