bottle heater relay or fuse?
Old Apr 24, 2007 | 09:56 AM
Camaro94SS's Avatar
Default bottle heater relay or fuse?
Instead of using a relay could i just wire a 30a fuse from the battery and then wire a switch in to control the heater? cause isnt thats what in a relay is 30a fuse? i have no idea which is why im asking
Old Apr 24, 2007 | 10:01 AM
Todd157k's Avatar
No. A relay is so that the high current line (in this case your heater) is isolated from the low current side (your switch). Putting 10+ amps through a switch is not a good idea. It can (and probably will) destroy your switch.
Old Apr 24, 2007 | 10:04 AM
Camaro94SS's Avatar
lol kk figured it wouldnt work but asked......so how do i know what relay to buy becuase im going to buy the heater alone?
Old Apr 24, 2007 | 10:06 AM
nahasapeemapetalon's Avatar
You could use a switch rated for 25A for example and eliminate the relay, I would recommend just using a relay. A relay does not replace a fuse, you would still need a fuse to protect the wire to the bottle heater. With a relay the power runs through it only if a signal(5V low current) is applied to it. Just like Todd said it isolates your switch from high current. So the switch doesnt have to be rated for high current with a relay setup. Just do it that way.
Old Apr 24, 2007 | 10:08 AM
Todd157k's Avatar
You can buy them anywhere. 12v automotive relays are cheap. I just bought a pack of 10, with a connector plugs, on ebay for $25. I use them on several other things too.
