What Single Controller Available with These Features??
Old Apr 30, 2007 | 04:06 AM
1QUIKWS6's Avatar
Active Streak: 30 Days
Question What Single Controller Available with These Features??
I'm looking for a single nitrous controller for my other T/A that can accomplish the following:
Window Switch (programmable)
Proggressive Nitrous Control (programmable for single stage - NX 85mm MAF wet system)
Lean Shut Off commanded by WB O2 Signal (I will have the PLX WB)
TPS WOT (not mechanical)
Obviously I will also have a FPSS.
I would like to use (1) unit that has all these capabilities instead of daisy chaining multiple units together.
Is there such an animal out there available? If not, what to use that would involve minimum number of xtra boxes?
-Jay-
Old Apr 30, 2007 | 05:53 AM
red fury's Avatar
mini FJO controller
Old Apr 30, 2007 | 07:04 AM
Gimp98TNT's Avatar
yep, FJO mini will do all that, plus RPM based ramps. And its pretty cheap too. Thats what im using.
Old Apr 30, 2007 | 06:56 PM
1QUIKWS6's Avatar
After doing some reading, it appears that the FJO Mini doesn't support the WB O2 Sensor input lean cut off.
For that feature to be included you have to go to the Maximizer2
Old Apr 30, 2007 | 08:59 PM
red fury's Avatar
or save some money by buying the FJO mini and a WideBand Commander A/F setup that has a programmable output features along with numerous other features. You could use one of the outputs to shut the nitrous down when the A/F reaches a set #.
For the price of the Maximizer2 you could get the FJO and the WideBand Commander.
Old Apr 30, 2007 | 09:09 PM
fast98's Avatar
im pretty sure the edge from hsw does all that
