ls1 dry nitrous install QUESTIONS -piccc-
Old May 3, 2007 | 11:42 PM
jeffboy757's Avatar
Default ls1 dry nitrous install QUESTIONS -piccc-
ok guys im putting together a very very basic dry shot. im not sure how to wire up the noid. what kinda current does it require and where would i wire up the relay. ive been told the ignition +12 will work, or should i use the battery and a relay. any advice would help ALOT. thanks
Old May 3, 2007 | 11:44 PM
JMBLOWNWS6's Avatar
No. Here I took your drawing and did it instead of linking you to instructions.
Old May 3, 2007 | 11:49 PM
jeffboy757's Avatar
oh thank you!! sorry i realized i was in the FI section so i moved it to here. i see that the arm switch is one that lights up, so ill see if i can find one at the store tommarow. your drawing looks much better
Old May 3, 2007 | 11:58 PM
jeffboy757's Avatar
so the noid is powered strait from the battery, and uses a 30 amp fuse, i didnt now it took so much to open one up
Old May 4, 2007 | 08:55 AM
wait4me's Avatar
If you want to do it better, Here is what i did. I used the Horn. BUT< What i did was put a relay at the front of the car where the horn was, so that when i flip the switch, the horn would work as normal. Then when i flip the switch on, then the nitrous would be active when i press the horn. It was very secretive, plus i still retaned the factory use of my buttons.
for you do do what i did, you just have to use 1 more relay. 87A is the output that would go to the horn, 87 went to the nitrous kit. 30 went to the wire going from the horn switch.
Old May 17, 2007 | 02:02 PM
jeffboy757's Avatar
Default nos
alright guys i have a problem thats pissing me off. im blowing fuses. i have everything hooked up right and cant find out whats wrong. so i tested the noid. i took out all the relays and stuff. grounded the noid, and put the other wire from the noid to the fused (30amp) positive from the battery. and boom it blows the fuse. is the noid broken or something??? help me out this is driving me crazy
Old May 17, 2007 | 02:59 PM
DynotuneN2O's Avatar
LS1TECH Sponsor
You must hook the solonoid up through a relay. Also, Based on your testing my bet is the solenoid is bad. You cannot hold the solonoid to direct power with no nitrous flowing through it. You can hit the solonoid quick to 12V power to see if it clicks, my guess is your will not. We use one of the highest quality solenoids on the market but even our industry leading solonoid will not weather continous power.
Dean
Old May 17, 2007 | 03:48 PM
jeffboy757's Avatar
yea it has always been set up through a relay. i just did the direct connect to the battery to see if i can hear the noid open. however it did have continuous power previous because i accidentally mounted a momentary switch that was normally CLOSED! grrr i finally got a normally open switch today. too bad i already destroyed the noid. ummm looks like ill be ordering another one heh
