Which blow down tube?
Old May 6, 2007 | 09:16 PM
its turbo time's Avatar
Question Which blow down tube?
Apparently i need a blow down tube to run at the track, but i don't know which one to get(90* bend or 180*). My bottle is mounted on the tunnel between the two back seats.
The kit is a HSW dry kit also.
I was looking at the quick release one on nitrous outlets page too. Is that a better setup?
http://www.nitrousoutlet.com/catalog...del=75&dept=11
Thanks!!
Old May 7, 2007 | 05:37 AM
1QUIKWS6's Avatar
Active Streak: 30 Days
When mounting the bottle between the seats it's actually easier and cleaner install to use braided SS hose/aluminum fittings from tank to a bulkhead fitting located underneath one of your seats.
The quik release wing nuts can be purchased to work with the aluminum fittings also - they are nice when removing tank for refill...
Old May 8, 2007 | 11:38 PM
Nitro Dave's Nitrous Outlet's Avatar
This is the best way to go.
http://www.nitrousoutlet.com/catalog...roduct_id=1116
Or you need a 180 degree blow down tube.
Dave
