new numbers in
99 motor
stock heads
ms3 cam only...
ls6 intake ported t/b
dynatech longtubes
asp underdrive pulley
through a built 4l60-e and yank 3600 stall
and 10 bolt with 3.42
made 360 hp and 390 ft lb tq...nice smoother lines and a/f was slightly fat at around 12.2 or so throught the run...so i was dissapointed, was hoping for 390hp and 410 or so tq
we pulled 2 degrees and hit the 125.....btw this is a nitro daves dual stage kit on only the first stage!
491hp and 523 ft lb tq...
car is setup for juice so im pleased with the juice numbers, also the was with some heat range 7 ngk plugs
http://s21.photobucket.com/albums/b2...t=IMGP0951.flv
stock heads
ms3 cam only...
dynatech longtubes
o yeah dave i meant to post the graph
http://i21.photobucket.com/albums/b2...o/IMGP0956.jpg
weird enough i have no purge so i though it would flash rich at the beginning....o well looks like some how it went slightly lean?
