TRex Cam only with spray?
Old May 13, 2007 | 02:15 PM
TN94Z's Avatar
Default TRex Cam only with spray?
I am about to put the bottle on my car this week to help me in a class I am running. Is there anything that I need to look out for as far as spraying with the TRex? I have read that there is no use in going over a 150 shot on this cam because of the overlap...but is there anything else? And am I correct in thinking that you add 2 degrees timing for every 100 shot or am I dreaming that?
Old May 13, 2007 | 02:29 PM
99Silverado5.3's Avatar
No take 2 away not add, and a 200 shot will be fine with enough fuel and good tune.
Old May 13, 2007 | 02:39 PM
TN94Z's Avatar
Take away 2...okay. I couldn't remember for sure. Thanks. I just want to spray enough right now to be competitive in this class. They are running 6.50s on spray and I am running 6.90s on motor. So I figure I will spray just enough to be at the top. And I am going to take the 5k stall out and put a neil chance 4000 nitrous converter in it. Thanks man.
Old May 13, 2007 | 05:08 PM
raymond mckinney's Avatar
i daily drive mine and spray it all the time ur be fine! Its all in the tune.
Old May 13, 2007 | 05:43 PM
TN94Z's Avatar
Yeah The car has been dyno tuned for WOT and from my WB it looks like it stays very close to 12.8 during the run. Now the idle is a different story. It runs pretty lean at idle. But of course I won't be spraying at idle.
Old May 14, 2007 | 09:01 PM
SOMBeast's Avatar
I just got me a t-rex cam too and was just wondering what did yall dyno hp/t?
