TA AC Vent Gauges
Old May 15, 2007 | 06:07 AM
dementia's Avatar
Default TA AC Vent Gauges
Well I guess my A/F gauge is supposed to be shipping out today (crosses fingers) and I want to install it in the center AC vent. I did a search but couldnt find anything on how you're supposed to get the vent louvers out though. Do you just pull them out or are there some clips I should be aware of?
Sorry if this is in the wrong forum. Wasnt really sure where its supposed to go and figured a few nitrous junkies have already done this on their cars.
Old May 15, 2007 | 10:55 AM
Low N Slow's Avatar
I worked a very small screwdriver in to help release the clips and just pulled them out. There are some clips that bite into the dash padding to hold them in place.
Old May 15, 2007 | 11:01 AM
SVC707's Avatar
yup just get a lil screw driver to pull the tabs out the way
Old May 15, 2007 | 11:02 AM
SVC707's Avatar
your same thread?!
https://ls1tech.com/forums/appearance-detailing/694818-2-1-16-gauges-ac-vents-pls.html
Old May 15, 2007 | 03:52 PM
dementia's Avatar
I know thats my same thread but I was wanting something more on the technical side. The small screwdriver tip is along the lines of what I was looking for whereas the other thread I just wanted some pix.
Old May 15, 2007 | 03:56 PM
SVC707's Avatar
you will also need to make a plate to hold the gauges themselves. you may use the materials of your choice, just be creative. finalize one then use the one as a template to make the others if you have more than one going in.
