Timing retard with nitrous?
Old Apr 27, 2003 | 06:25 PM
B4C CAMARO's Avatar
Default Timing retard with nitrous?
Does the computer require timing reprogramming with nitrous, or does it adjust itself?
Old Apr 28, 2003 | 03:10 AM
383LQ4SS's Avatar
Default Re: Timing retard with nitrous?
If your going to spray over a 125-150 shot you should have the Ramchargers Timing Tuner to pull some timing. The computer will not do it for you.
Old Apr 28, 2003 | 07:22 AM
Reckless's Avatar
Super Moderator
I run about 29 degrees on the motor, and 25 degrees on the spray.
