Nitrous shut-off rpm?
Old May 19, 2007 | 11:44 PM
jbone's Avatar
Default Nitrous shut-off rpm?
Yeah I was wondering, how many rpms should my nitrous cut off before my rev limiter? Im running a wot switch that I can set to stop sparying whenever. Thanks.
Old May 20, 2007 | 01:23 AM
transamfreak01's Avatar
with a window switch you can have it set to w/e u want it. what are you planning on spinning the motor to?
Old May 20, 2007 | 09:58 AM
dnkynrbk's Avatar
My rev. is set at 6700 and my shift point is at 6400 I have my msd window switch set at 6300 to shut off. Hope this helps
Old May 20, 2007 | 10:18 AM
bonestockz06's Avatar
100-200 rpms before your shift point is usually where you want it to shut off.
Old May 20, 2007 | 12:17 PM
yup yup
Old May 20, 2007 | 05:16 PM
jbone's Avatar
Thanks a lot guys
Old May 21, 2007 | 12:59 PM
adown's Avatar
With an automatic, cant you spray through your shift? I understand shuting of before shifting a manual(WOT switch), but with an auto I'd spray almost to the rev limiter. Or just under valve float which on a stock ls1 I'm told is about 5800-6000.
Old May 21, 2007 | 05:49 PM
if you spray through shifts it will mess up your trans... thats the reason for the controller so it shuts off between shifts
Old May 21, 2007 | 05:54 PM
BTLFEDSS's Avatar
Mine shuts off at 6300 as i shift 6400-6500
BTLFEDSS
