FJO question
Old May 23, 2007 | 08:33 PM
LS1SpeedAddict's Avatar
Default FJO question
I have an FJO mini controller and I trying to set it so it wont activate when I use the trans brake. I'm 90% sure I did everything right but I just want to double check before I blow my engine. I set it so input #2 activates with 12volts and Input #2 will disable the 1st stage. Is that correct? I only have one stage and I know it wired correctly.
Old May 24, 2007 | 06:27 AM
NXRICKY's Avatar
Closed ex-Sponsor Account
yes as long as that wire sees 12volts when you push the tbrake button.
Old May 24, 2007 | 06:36 AM
thanks for the help
