i need some help with my timing tuner
Old May 24, 2007 | 01:48 AM
daniel6718's Avatar
Default i need some help with my timing tuner
ok i bought off a board member hes being really cool...but we cant figure this out...
ok i oblivously and treying to put this on an ls1, but when i plug it in, i simply installed the bypass plug to make sure its all good, and the car wont start
so i pulled it off checked al the wiring with a volt meter and they are all good...put it back on and still no start....
he said it was working with the bypass plug in his car before hand...
i cant think of any reason why i cant plug in the bypass plug and make it work...idont know what coltages are on each wire, i think the crank sensor has a power ground and signal...i guess i could check them? throught the harness and to the bypass plug? any ideas?
Old May 24, 2007 | 04:51 PM
daniel6718's Avatar
did yall mis my post? or nobody has a clue?
Old May 24, 2007 | 07:57 PM
MetallicaMatt's Avatar
I've had the problem where I forgot to put the bypass plug lol
I would check the plug to the crank sensor, make sure shes on there good and nothing else got bumped or disconnected
Old May 24, 2007 | 08:38 PM
daniel6718's Avatar
ive checked all the prongs...the bypss plug shorts the yellow and green wire together...
theres a pink and black, are these 5v and groujnd or 12v and ground?
Old May 24, 2007 | 09:32 PM
I'd have to check mine tomorrow after work. I don't remember off hand
give manufactur a call tomorrow, they are good with tech support
Old May 25, 2007 | 04:10 PM
daniel6718's Avatar
who is the manufacturer?
