what
Old May 24, 2007 | 02:11 AM
droptopT/A's Avatar
Default what
nitorus system that is easy to install and cheap and how much does it cost
Old May 24, 2007 | 03:31 AM
~RedLineLs1~'s Avatar
Any single or dual nozzle system whether it be wet or dry will be pretty easy to install. All of the nitrous sponsors are pretty affordable IMO but after all the safety goodies (WS, FPSS, heater, plugs, etc) you'll probably be close to around $800. Give or take depending which kit you decide on. Too many variables to give you a solid price. I would talk to the sponsors on the board and decide from there. HSW, Dynotune, Nitrousoutlet, NX, etc are all great to deal with.
Make sure to read the stickies. There is a lot of good info in them which will probably answer most of your questions.
Old May 24, 2007 | 04:38 AM
Beer99C5's Avatar
Well said Redline!
Old May 24, 2007 | 01:51 PM
Chris@NitroDaves
Guest
Posts: n/a
What mods are done to your car? What mods do you plan on doing? Depending on what system you want ( Wet or Dry ) there are several options to choose from. If you are looking for a very easy install and very user friendly system then I would suggest the Zex ( Wet ) system this kit is adjustable from 75-125hp LINK. If you were wanting to do a dry shot then there are several options to choose from LINK they range from $499.00 to $349.99. If you wanted to go with a wet system ( Me persoanlly I would go with a wet system ) you also have several options. One of the most popular options that most people are using is our plate system. It provides a very clean install and comes adjustable from 50-200hp 78mm System or 90mm System.
-Chris
Old May 24, 2007 | 07:22 PM
Robert56's Avatar
A small dry or wet kit would be real easy, and the price will go to the dry. Just do some research and decide if ya would like wet or dry, then choose a site vendor and have some fun. A 100hp kit will generally knock an easy 1.00 off your ET when basically a stock car.
Robert
