3 practical nitrous newb questions
) and this has to be the best nitrous resource ive found on the web. Picked up a dry shot system from a friend. Want to install it on the wifes 2005 Miata. (Im used to a 13.1/105mph Stealth Twin Turbo. Mazda = 138hp
)Q1: I want to go dry shot. Ive seen nitrous backfires. Will a dry shot prevent the possibility of a n20 backfire? (unless something else goes horribly wrong)
Q2: It has a return-less fuel system. Im wondering if a system that sprays into the filter (like picture below) would work without having to hook up a fuel pressure switch? (as the car doesnt have an FPR) Could I just spray through the MAF to trick the pcm into upping the injector duty cycle to keep up with the dry shot? Seems a little hit and miss with getting the right af ratio this way... But would be a nice simple system if it worked.
Q3: Basically is there any way easy way to run a small (50 or under) shot on a returnless fuel system? Everyone tells me I have to go wet. Am I just being difficult?
Thanks for any thoughts you guys have.
Picture of The Smurf!
Robert
A) will dry shot (reasonably) prevent the possibility of an intake backfire?
B) There is no fuel pressure regulator. There is no return line on the fuel system. would injecting through the MAF alone, be enough to trick the PCM/ECU be enough to keep the A/F ratio safe?
PS Heres a few pics I took today of La Zee! (blue one) LG long tubes, Off road X-pipe, Stinger intake, Torque tube cover plate thing, frame protectors, lowering bolts, and some other little stuff.
