June Nitrous Specials!!!!!!!
How much is shipping to 38654?
Thank you for all your interest. The only deals we have going right now are posted. Shoot us a pm if you have any interest on anything not posted and we will put some priceing together for you. Otherwise you can wait and see what we have next month.
Thanks for your support.
Dave
i had just made an order on 5/14/2007, and here it isautomatic heated bottle bracket 216.5
window switch 129.
tr6 plugs 15.92
T SHIRT 14
dual vent purge 34.99
big show purge 119.
halo system 499.99
for a total of 1,029.40
i know i ordered the big show purge instead of the regular (do i need a harness?), and the bracket heater, but is there anyway i can get refunded for some kind of a discount? i just threw down a lot of cash and i sure could use and would appreciate some kind of refund...
show me that top of the line customer service!!Thanks
Dave
I retract my earlier statement. I just pulled up your order. It shows that you have recieved everything to start your install but we are still waiting on the Halo spray bars to come in from fabrication. So you still have not recieved that part of your order. That is Rediculas!!!!! I will do something to help you out.... However I am going to leave my earlier statement for others that are reading along. This way we do not have any future problems when we post specials.
Thanks
Dave
Dave
Fort anyone that has not ever had the prevledge of seeing one of our dedicateds in person. The designs are top notch for the best fitment possible. The weld could not be any better. And ythe unit is fully assmebled Simply wire the system up, cut to fit the feed hose, and adjust the fuel pressure.
Thanks
Dave
How big are the noids? Are they compatible with a progressive controller?
The standard kit will support up to 150...if you want to spray more you will need a 1/8x4an fitting and a SHO line (~$25). With this they will support 250+.
The solenoids are 300+hp Solenoids
Yes they are designed to handle being progressed
Can someone tell what I need to know to run it from the bottle in trunk to a gauge pod?
Pretend I am a rookie.
Will that $37 zex one fit in a pillar pod?
What fittings do I need for the gauge and to conect to bottle?
What kind of lines?
Im worried about buying all the wrong stuff.
thanx
What kind of lines?
thanx
