how much spray on a build bottom end
Old Jun 1, 2007 | 05:24 AM
coolchevy's Avatar
Default how much spray on a build bottom end
finicky question, first I list what has been done to engine (2000 Vette 6-speed):
forged JE 11.3:1 pistons, Hellfire rings
Compstar rods
stock crank
ARP studs everywhere
CNC CMS heads stage 3
hefty 230/234 cam at 114 LSA
FLP headers, no cats, BB PRT exhaust
Fidanza flywheel, Specs clutch
full roller rockers
aggressive tune gave 550hp / 485 ft/lbs@ engine
full separate way oversized fuel system just for nitrous, could handle a 600hp shot if it had to be
we added a hidden nitrous system which can 150/200/250 and 300 shots.
Since NA tune shall stay the way it is for highspeed blast down the Autobahn at 34 degrees and 100 octane premium gas we installed a timing tuner and pull 9 degrees when on nitrous. We want spray in 3rd gear onwards only as out tracks can't handle a 2nd gear shot at all.
pushing a 150 shot in 3rd gear gives sort of disappointing results, even when I take time base ramp completely out of FJO. How much could be safely sprayed when we try to stick with a 11.9 A/F?
Old Jun 1, 2007 | 05:38 AM
blacktransam's Avatar
give it hell and go 300.. just make sure the tune is on..
Old Jun 1, 2007 | 06:05 AM
99Silverado5.3's Avatar
Old Jun 1, 2007 | 06:16 AM
mr2guru's Avatar
Probably all depend on ring gaps once you go over 250.... Parts used would have no problem holding 300+hp shot.
Old Jun 1, 2007 | 09:30 AM
coolchevy's Avatar
not sure if I have the guts to go to 300shot. But I will try a 225 I guess and go down to 22 degrees timing............
Old Jun 1, 2007 | 08:07 PM
v8-7's Avatar
****, you can do that on the stock engine!
Old Jun 1, 2007 | 08:18 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Quite a few guys running 200 shots. A guy on the truck side sprayed a 250 shot on his 6.0 I have read where a couple guys have sprayed 400 shots on the stock crank, I dont think I would though.
