What size injectors for a 200 shot on a 422
Old May 1, 2003 | 12:32 PM
silent1's Avatar
Default What size injectors for a 200 shot on a 422
I'm in the process of building an iron block 422 and was contemplating a 200 shot. What size injectors would I need to safely run this set up? While I'm at it, what fuel pump would you guys recommend? Thanks for any info.
Old May 1, 2003 | 01:15 PM
Reckless's Avatar
Super Moderator
Default Re: What size injectors for a 200 shot on a 422
Unless you are running a dry system, injector size is not important. I really doubt you are thinking of a 200 dry shot.
Pump may be of concern for a wet kit. I would upgrade it.
Old May 2, 2003 | 12:08 PM
smokinHawk's Avatar
Definatly go with wet on a shot that big.
and a direct port with that.
