New to nitrous and just ordered kit. Got a couple questions!
i just ordered a HSW wet kit for my LT1 with purge kit, blown down tube kit, RPM window switch, FPSS, custom LT1 switch plate and a brand new HSW bottle blanket off ebay. I'm planning on 100 shot with it. Anyway, will Autolite 104 plugs work ok with this nitrous setup? i've read they are another good plug for Nitrous. also with my madz28 tune am i gonna be ok to run a 100 shot or should i lower the shot down to say 75? Or what else should i do to it to make it a good safe setup? Thanks~Cole~
1st time around, i would go with the tr6's since most people on here use them. i would also log at the very least afr.
i don't know what your tune is, but wet should be with the nitrous and fuel jets.i would also log at the very least afr.
and you want a heater too.
i got a heater
but i don't have the stuff to do a A/F if that's what you mean by AFR. Should i send my MadZ28 tune in and have him put it back to stock timing instead? I don't want to blow it up but i don't know what other stuff i need.
but i don't have the stuff to do a A/F if that's what you mean by AFR. Should i send my MadZ28 tune in and have him put it back to stock timing instead? I don't want to blow it up but i don't know what other stuff i need. Last edited by Cole Train; Jun 6, 2007 at 01:57 PM.
Guest
Posts: n/a
I would reccomend the Mallory 685..if you don't already have an ignition box.....this will let you keep your NA tune, and retard the timing when the kit activates.
This is why everyone was reccomending it in your last post. It also includes a window switch, and will increase performance NA also.
