Single Stage Wiring question
Old Jun 6, 2007 | 06:41 PM
exige4's Avatar
Default Single Stage Wiring question
quick question for you nitrous guru's, me and my friend are spraying his Stratus 3.0 with a 50 shot this weekend for shoots and giggles. The way i got the kit, was with this wiring. Both Positives from the Compucar Purge and NOS solenoid are pared together and ran to a toggle switch, the negatives are grounded out to the battery. From the toggle, there are two push button switches ran, one for purge, one for spray. When I test wired it on my GTO, i could only get the purge to work, the solenoid for the spray did not click on. When I direct wired the solenoid to the battery, it of course, clicked on. What could be the problem here, and if anyone has some very simple diagrams for a single stage NOS with purge, no FPSS, post it up. I checked under the wiring diagrams, and did not see one applicable to my kit. Thank you.
Old Jun 6, 2007 | 11:23 PM
SY732's Avatar
Sounds like the load is more than the switch can handle run a relay.
Why waste your time with a purge?
Have fun blowing it up
Arming switch
+ to a switched positve
acc to 86 on the relay
- to a ground
Ground the noids to a good ground
Run the other noid wire to 87
30 to ground
