300 shot... Which type of system
Old Jun 7, 2007 | 12:50 PM
PowerShift408's Avatar
Arrow 300 shot... Which type of system
I've been looking into which type of system to use for this large of a shot, so I'll ask the nitrous gurus. What are the advantages and disadvantages of a twin nozzle system compared to a throttle body plate system, or any other type of system for that matter.
Old Jun 7, 2007 | 01:10 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
for a 300 shot I would higly reccomend a direct port system...it will give you the ability to tune each cylinder independantly....on that size shot you need to make sure you are getting even distribution.
Old Jun 7, 2007 | 01:34 PM
383LQ4SS's Avatar
Whats the total HP goal. Nitrous + motor? Are you on a stroker making big NA power already? Or a forged 347 making good power?
Old Jun 7, 2007 | 01:39 PM
Currently, it's a cam only 408 (I know, retarded) making 432 rwhp, 431 lb./ft. of torque through a twin disc clutch and 9'' rear end. I'm figuring that with a nice set of Trickflow 225s and a ported Fast90, It should make right over 500 rwhp. The motor was built with a 300 shot in mind. With that said, I guess I'd like to shoot for 800ish rwhp.
Old Jun 7, 2007 | 01:44 PM
I'm guessing with this sizeable of a shot, race gas may become a factor. What do you guys think?
Old Jun 7, 2007 | 02:18 PM
Flaco's Avatar
you are way better of with a direct port and seperate fuel cell with 112 or 116 octane> cant go wrong with that, plus the advantage is that you can still run a bit more timing.. Used to have a stock type bottom end ls with h/c combo and a 250 shot with 29 deg. of timing still running strong .. JUST REMEMBER TO CHECK PLUGS OFTEN AND A/F .. HAVE FUN
