fjo mini controller
Old Jun 8, 2007 | 10:55 PM
t6378tp's Avatar
Default fjo mini controller
ok I installed my fjo controller today and now the nitrous does not activate.
I nitrous setup was work fine before the fjo, I think it maybe installed wrong
I have the rpm wire goes to my msd box
the white wire is tied into the power wire that leads off the arming switch to the relay
the red/white wire is going to the wot switch and the other connection from the wot switch is a ground
does anyone have a wiring diagram or some tips for installing this controller
Old Jun 9, 2007 | 10:05 AM
t6378tp's Avatar
I guess nobody here is using this controller ?
Old Jun 9, 2007 | 11:18 AM
NXRICKY's Avatar
Closed ex-Sponsor Account
CLick your wot switch, and look at the LEDs on the box, see if the one of them lights up. if not the box is programmed wrong and needs to be set to a falling or grounding switch.
Ricky
Old Jun 9, 2007 | 11:56 AM
t6378tp's Avatar
Ricky
ok I checked the relay with the arming switch on and it's getting 12v
but when I turn the key on but not start the engine the green light is blicking also with the engine running the green light blicks
I did press and hold the button on the controller in by mistake, do I need to reset the controller
also I uploaded a new program basicly making the controller into a window switch and still nothing the yellow light does turn on and off at the pre-rpms
but no nitrous
I am using a wot switch should the leads to this switch be a ground and input wire from the controller
I also have been searching the web looking for a diagram or tips on installing this controller anything hopefully leads back to this site but all the diagrams are gone does anyone have them saved
Old Jun 11, 2007 | 09:59 PM
Black X's Avatar
a blinking green light means the unit does not have proper calibration of the wot switch. Go through the calibration procedure again.
Old Jun 12, 2007 | 06:54 AM
Johnny5's Avatar
So you are using a WOT and the FJO controller? You should only need the controller linked to the TPS sensor. (I may have misread the post above)
If you search for FJO and Johnny5 as a user I listed out all of the settings and such.
Old Jun 12, 2007 | 05:51 PM
t6378tp's Avatar
nxricky was helped me program it, the problem was I was trying to program it with the car running
Johnn5, I am runnning a carb so no tps
soon as it stops raining here I am going to test it out
