modifying nozzles
Old Jun 8, 2007 | 11:20 PM
bcbosley's Avatar
Default modifying nozzles
I have a HSW single dry nozzle kit with 70 degree nozzle. My spraying angle wasn't right so I bought a NOS 90 degree fan spray nozzle. My HSW jets wouldnt fit the nozzle so I drilled the nozzle out to fit the jets and I needed more like a 110 degree angle so I ground the wedge of the nozzle to give me more of and angle. Will these things cause any harm?
Old Jun 12, 2007 | 05:27 PM
bcbosley's Avatar
Nobody has modified their nozzles?
Old Jun 13, 2007 | 08:55 AM
ShiznityZ28's Avatar
The problem with modifying the nozzle is when a nozzle is designed they flow them and make sure they have a good spray pattern and on a wet nozzle they mix correctly. I would connect it up and make sure the spray pattern is still good.
Old Jun 13, 2007 | 09:18 AM
Nitro Dave's Nitrous Outlet's Avatar
On a dry nozzle you should be fine since you are not trying to attomize fuel with the nozzle.
Dave
