I need help!!!
Old Jun 9, 2007 | 12:24 PM
azceta's Avatar
Default I need help!!!
I have an 02 TA and installed a wet kit but cant seem to get a tach signal. have a msd widow switch and was told that i needed the dis tach box also. Please help!!
Old Jun 9, 2007 | 12:44 PM
TN94Z's Avatar
What kind of connection did you use to tap into your tach wire?
Old Jun 9, 2007 | 12:48 PM
azceta's Avatar
solder and heat shrink. I dont even think its the right wire. Was reading around and been getting told to use different wires from different places. One person said use the LT Green/ white from one of the coils. Another said its some blue wire running down the fender. Any Ideas?
Old Jun 9, 2007 | 02:11 PM
TN94Z's Avatar
This is a quote from install university.com
"If you have a 1999, 2000, 2001, or 2002 model F-Body you will need to pop the gray case off of the lower part of the PCM. If you have a 1998 model you will need to pop the gray case off of the upper part of the PCM. Gently squeeze then ends of the cover and pull. They should pop out fairly easy. Then repeat this step on the opposite end. Once this is done just pull the cover completely off."
"1999, 2000, 2001, and 2002 model F-Body's should locate the number ten (10) pin (see blue arrow Figure 4). The wire should be white in color. 1998 model F-Body's should locate the number 35 pin (in the upper cover) and the wire should be white in color."
Hope this helps you out.
