2 stage question
Juan
1 Switch Power Both Stages Then 1st Stage To Work Only At Open Throotle Then The Other One To Only Work When You Press The Button So You Can Hit The Second Stage When Ever You Need It Only And In The Track Only After The 60 Footer Then Keep Both Stages Working To The End Of The Track. I Want It Like This Because Of The Traction Problems And So My Differential Wont Break That Easily
