couple questions for halo owners
I have a dynotune setup, but just got a halo and some jets. i went to install it, but it wouldnt sit flat on the filter, so how do i get it flat. also, what is that tab for on the drivers side? and last, am i supposed to tighten that nut all the way down to the feed line on top of the filter?? thanks for any help guys
It is all in the adjustable tube (feed line) that the halo connects to. It is fairly pliable. Make sure that it sits low enough that it actually pulls the halo bar down into the filter. I'm sure mine wasn't sitting "perfectly flat", but it was close enough to close the lid, and sprayed like a champ. I was very hapy with the results! I have no idea what that tab is for. Yes, tighten the nut all the way down, about half a turn past what you can do with your fingers. Hope that helps.
