Another how much ?
Old Jun 17, 2007 | 06:23 PM
1FSTLS1's Avatar
Default Another how much ?
So i just ordered my typhoon intake and now need a tb. Thinking of the new one from summit price is great but it is only 85mm. So after i get that on i want to spray. My question is how much can i spray if any w stock injectors and not messing with my timing? I figure i can go with a low shot then when i want more i can do my fuel pump injectors plugs ect. I was looking a the harris speedworks dry kit either dual or single stage. Any input would be greatly appreciated.
Old Jun 17, 2007 | 09:51 PM
transamfreak01's Avatar
with a dry kit id say around 100 to 125 you would have to change injectors. if you go with a wet kit you wont need to changed your injectors. so iono its up to you
Old Jun 18, 2007 | 01:27 PM
1FSTLS1's Avatar
Never heard that one. If i go with wet hows my stock fuel pump? And can i leave my timing alone for a while?
Old Jun 18, 2007 | 02:04 PM
yeah the timing should be fine and a lot of people still run their stock fuel pump depending on how much they spray... how much are you planning on spraying?
Old Jun 18, 2007 | 02:44 PM
1FSTLS1's Avatar
Was thinking i would start small. 75-100?
