wot switch
Old Jun 19, 2007 | 05:20 PM
GT Griller's Avatar
Default wot switch
2 quick questions...ok can i wire up my WOT switch up into the cab of the car and use it like a push button system where i can hold it down manualy say with my finger and let off when im done with the run?
2nd...my WOT switch has 3 prongs on it which 2 do i connect the power and ground to?
Old Jun 19, 2007 | 10:53 PM
Todd157k's Avatar
1. yes, but very dangerous. You could shoot w/o being wide open.
2. It's not a "pwr/gnd" switch. It's a "connect/disconnect". You wouldn't be running pwr and ground to that switch. think of it as an interruption in one electrical line. If you run a ground wire to it, it will be ground coming out of it. The switch has markings:
N.O. = normally open. connecting to this terminal means there is no connection until the switch is activated.
N.C. = normally closed. connecting to this terminal means it is connected until the switch is activated (opposite of above)
C = common. This is the terminal for your incomming line regardless of which way (N.O. or N.C.) you use.
Old Jun 20, 2007 | 04:36 PM
GT Griller's Avatar
Ok on this picture im seeing some power coming from the arming switch tho and the other end into the relay.....but my real problem like i said is that all wiring diagrams i see are for WOT with 2 prongs and mine has 3 which 2 do i use? I knew u labled them for me but which ones do i connect to what? Im assuming "C" is from the toggle switch then "N.O" to the relay?
