pics of my wot switch....
make a bend sorta like an sjust after were the bolt goes through the bracket...use the front bolt of the throttle bracket...the reason for the bend is to clear the pcv hose on the tb....the micro switch needs to face the tb also with the trigger facing the front of the car....
now that the switch is mounted next to the throttle cam...roll the throttle all the way back to the bumpstop...
make a mark next to the wot trigger...drill a small hole through the throttle cam more to the top so the cable is still loose...insert a small bolt through the cam...the bolt should activate the trigger if done correctly...
I took a few better pics and a vid....sorry about noisy kids in vid....heres video
front view side wiew
Itried puttin images in the thread but they didnt show up.....
