running the nitrous line
Old Jun 28, 2007 | 12:23 PM
SpecterGT260's Avatar
Default running the nitrous line
Where do you guys run the line? The bottle is going in the spare tire well. I am having a hard time finding a place to get through the firewall. Are there any spare gromets in the firewall to allow access?
Old Jun 28, 2007 | 12:49 PM
5_02ls1's Avatar
run it under the car...theres a grommet under the pass side seat....
Old Jun 28, 2007 | 12:50 PM
i did not know that.. thanks
so run it to the pass seat, then out the bottom, then up beside the engine? I was hoping for one right through the firewall, but that will work i guess
Old Jun 28, 2007 | 12:55 PM
5_02ls1's Avatar
you might drill a hole but it would be big and I wouldnt do it....theres plenty of places underneath to tie the line to....
Old Jun 28, 2007 | 01:55 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
there is also a grommet where the PCM wires go through the firewall
Old Jun 28, 2007 | 03:08 PM
bjamick's Avatar
Thats what i used
Old Jun 28, 2007 | 04:45 PM
98TADRIVER's Avatar
i popped my side vents out of my 98 trans am and drilled right thru it. driver and pass sides.
Old Jun 28, 2007 | 06:02 PM
A buddy told me about that one. thats where I went through and where all my wires will pass. There is plenty of room in there. Thanks guys
Old Jun 29, 2007 | 12:42 AM
DropTopBird's Avatar
If memory serves me right, isnt there a grommet or drain plug in the spare tire well/trunk area that you can use and then just run the line under the car to the engine?
Old Jun 29, 2007 | 01:26 AM
Ramshaft's Avatar
Yeah there is, I did that with my first line and it worked for a while but it got to close to the exhaust and ruined the line, Now it is running down the pass side of the car and throught the PCM area under the dash.
Old Jun 29, 2007 | 01:35 AM
BayAreaSS's Avatar
I ran my line from the spare tire area under the carpet along the passenger seat and to the grommet behing the PCM
Old Jun 29, 2007 | 07:18 AM
NHRATA01's Avatar
That was the problem I saw. I had wanted to run it underneath, but couldn't find a way to run it up into the engine bay without getting to close to the headers. So I ran it inside under the carpet.
Old Aug 6, 2007 | 01:04 PM
sworaz's Avatar
That's a helpful thread......I spent a couple hours trying to find a place to run my line and after finding this thread I found the gromit to run my line through
