Put 200 Jets In
what do you guys think. i took the car from a 10mph roll to 90 and the a/f stayed between those numbers. do you guys think i'll be safe with the 200 jets?
the car pulled great and there was no sign of knock.
thanks
Eric
If you want to be absolutely safe take it to a dyno and make a few pulls to verify a/f. It's pretty cheap and a good way to see how accurate your a/f ratio gauge is.
I hope you're running around 2 heat ranges colder than stock with a slightly smaller plug gap than on the 150...
thanks
Eric
Make sure you have enough fuel pump.. And if you have a stock bottom end just know you are walking on ice.
Dave
