Dynotune two stage cam only LT1 11.002
After I get the nine inch under it I will get some 10 second passes in.
I had problems trying to spray both stages on the dyno. So I bypassed the time delay, replaced the relay on the second stage and sprayed both out of the gate. Lifted the tires and pulled a 1.483 60 foot time. Before the 10 bolt broke.
150 shot--------------------------------------210-220 total both stages
The 11.002 at 112 would of been a 10.9 at 125 or so if I could have stayed in it. The car got loose and I let up on it. If you look at the first slip (on the 150 shot) 11.22 at 121 should be the proof that I got out of it.
