Do you think this will work...
Old Jul 3, 2007 | 05:14 PM
REDSS98's Avatar
Default Do you think this will work...
I have 98SS with LT,ORY, loudmouth,6m,nittos,I was wanting to put a 100 shot on it. Going to order this tomorow tell me what you think,what else I need,saftey or other.
Dynotune 8cyl dry system
Dynotune two stage RPM window/TPS switch
Fuel press. saftey switch (d.t)
A switch panel from Nittro Daves With ARM,heat,Purge,pressure gauge
Latter on a bottle heater,and puge kit
Old Jul 3, 2007 | 06:40 PM
BayAreaSS's Avatar
Looks like you have it covered...dont forget a set of colder spark plugs.
Old Jul 3, 2007 | 08:08 PM
John Junkins's Avatar
Default Redss98
REDSS98,
This switch rocks, I have the same switch and look great.
Sound like a good setup.
Old Jul 3, 2007 | 08:26 PM
REDSS98's Avatar
Thanks kinda new at the nitros game. thanks for all the input.
Old Jul 3, 2007 | 08:27 PM
REDSS98's Avatar
I did forget about the plugs thanks BAY
Old Jul 3, 2007 | 09:13 PM
REDSS98,I would go ahead and run the wiring for the heater and the purge. If not it's a pain to run later. I would also add a couple of relays in the mix. I found out the hard way on that.
John Junkins
Old Jul 3, 2007 | 10:12 PM
BayAreaSS's Avatar
No problem.
I also ran a separate relay for my heater.
