Can I spray the 125 shot?
Old Jul 16, 2007 | 07:06 PM
its turbo time's Avatar
^ whats the easiest way to convert my single nozzle to a dual?
Old Jul 16, 2007 | 07:48 PM
Robert56's Avatar
Just get a hold of one of the vendors.
Robert
Old Jul 16, 2007 | 08:36 PM
BobDoLe's Avatar
i have a 99. i spray my 100 dry shot at 1000psi and i'm at 99% injector duty cycle.
i use hptuners and so i have taken out a few degrees of timing past .76 g/cyl. no lean spike, and my narrowband o2 sensors are registering 900+mv (actually 902mv bank 1 and 941mv bank 2). i realize my injectors are smaller, but i would seriously consider upgrading injectors.
hptuners thinks i'm putting out 480+ lb of torque. i assume it's inaccurate because the pcm thinks i'm taking in more air than i really am. anyone else with hptuners use the torque pid?
Old Jul 16, 2007 | 10:53 PM
Couple questions...
How big are the 99 injectors?
Have you ever run your car? If so, how did she do?
How accurate are the millivolt readings on a narrowband? Are they usefull enough to tune with?
Old Jul 19, 2007 | 12:39 PM
BobDoLe's Avatar
Originally Posted by its turbo time
Couple questions...
99 injectors are 26.4lb/hr... they max out and hit 99% duty cycle, but the o2 readings maintain no lean spike and no knock (that my knock sensor can detect).
we have an 1/8 mile track here, but i've been hesitant to run there - not interested in upgrading rear end to handle DR hook and not enough traction to hold the nitrous shot early enough to make a difference on the short track. i'll likely end up there in the next few weeks, but i'd prefer to drag some people with me out to the closest 1/4 mile track.
here's a shot of my hptuners data. you can see the INJector readings jump and the timing drop when the nitrous hits. i think i'll switch to a dual nozzle setup for reasons others mentioned. i notice my iAT barely moves.
Old Jul 19, 2007 | 10:54 PM
BriancWS6's Avatar
Sorry for the lack of response on my part. I moved and just got my internet up and going again at the new place yesterday. Looks like your all squared away though.
Old Jul 20, 2007 | 09:10 AM
With stock 02's my millivolt readings are pretty steady at 940ish while spraying(after i moved my nozzle of course), i was told that that is about 12.2 afr, im planning on just leaving it be. Haven't had a chance to take it to the track yet, its just been too damn hot...milk was a bad choice
