Fuel Supply?..
Old Jul 7, 2007 | 09:00 PM
LS1Silverado05's Avatar
Default Fuel Supply?..
Where do I get fuel for the fuel solenoid from?...I am assuming the rail at the schrader type fitting?...Where do I get an adapter to make it work? I am piecing together my system here. I have the bottle, Nozzle..and the solenoids, but I need all the supporting items. I have found window switches, and microswitches etc....But I need that fuel rail adapter.
Old Jul 7, 2007 | 11:17 PM
BayAreaSS's Avatar
You are going to need one of these gauge adaptors to connect your line to the fuel rail.http://www.dynotunenitrous.com/store...?idcategory=42
You will need to take the schrader valve out of the fuel rail.
Old Jul 8, 2007 | 01:08 PM
mrr23's Avatar
you don't need an adapter. the fuel rail is a -4AN already. just need to pull the schrader valve out of it and screw the fuel line right onto it. the fuel line has a -4AN fitting on it.
or, you can do what i did. i used a -4AN to -4AN female fitting and screwed it right to the rail.
Old Jul 8, 2007 | 02:31 PM
BayAreaSS's Avatar
I guess it depends on how he wants to run his FPSS as well.
Old Jul 8, 2007 | 05:34 PM
mrr23's Avatar
well, if he has one, then he'll need a -4AN feamle to -4AN male adapter with 1/8" NPT hole in it. but, he did not specify that he had one.
here's that adapter to use russell 670290
http://www.jegs.com/webapp/wcs/store...0002_373808_-1
Old Jul 8, 2007 | 05:47 PM
Thanks guys!
