How Much NOS is to much????
Old May 12, 2003 | 10:21 PM
ChazLS12002's Avatar
Default How Much NOS is to much????
I'm having a Vigilante 3200 RPM torque converter and 3.73 gears installed, Would it be to much to add a 150 shot of NOS with a full throttle switch for a daily driver???
THANKS ALREADY
Old May 13, 2003 | 07:09 AM
Argon Z's Avatar
Default Re: How Much NOS is to much????
i saw an article in a few years back where they took a stock block and put as much nitrous on as the block would take before ka-boom it took somthing like 350 or so.
Old May 13, 2003 | 07:20 AM
last of the Z28's's Avatar
holy ****!!!! a 32,000 rpm stall? my god the car is going to rip in half!!!
from what ive read 150 shot before you have to really start messing with the fuel system. just do a 100 or 125 shot. you can do that all day long on a stock system. just dont spray in to low of an rpm or through your shift and it should hold up nicely.
Old May 13, 2003 | 07:57 AM
Rice Burner's Avatar
Naaaaaaaaaas!...... :pMaybe you mean nitrous?....I apologize if you are getting nitrous oxide systems (NOS)
Old May 14, 2003 | 12:41 PM
sawedoff's Avatar
THANKS ALREADY
You shouldn't have any problem with that setup. It all depends on how strong the bottom end is. With a factory lower rotating end, it just depends on how well it was built, but alot of people have real good luck. Your mileage is going to suck major ***, though, with that stall and low rear.
