2 step w/ nos mini controller ?
Old Jul 12, 2007 | 12:17 PM
bowtierodder's Avatar
Default 2 step w/ nos mini controller ?
which wire on the relay would the yellow from the 2 step go to? so the nitrous is deactivated at wot on the 2step.......... i cant figure out how a switched ground(yellow from the 2 step) will keep the nitrous from activating
Old Jul 12, 2007 | 01:15 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
what brand 2 step is it and I will see if I have a diagram that will work....if it works the way I am thinking you will use a 2nd relay to deactivate the nitrous relay while the 2 step is active
Old Jul 12, 2007 | 01:23 PM
it a harlans 2 step, with the nos plate kit(p#05168) and nos mini controller(p#15974).thanks for the help
Old Jul 13, 2007 | 07:28 PM
bump for ray's response
