"The Angle" progressive controller
Old Jul 19, 2007 | 11:47 AM
its turbo time's Avatar
Default "The Angle" progressive controller
Whats the general opinion on this piece?
http://www.harrisspeedworks.com/shop...cat=338&page=1
Also, im spraying a 100 shot at 2750 rpm, could i spray earlier with this; maybe start spraying at like 2k with this activated, then spray the full 100 shot at 3k?
or is that even the point of this thing?
Old Jul 19, 2007 | 11:51 AM
ALLBOTTLE's Avatar
LS1TECH Sponsor
Why are you racing @ 2k RPM?
Unless you Have a DP setup it's not recommended that you spray below 3k RPM to help minimize fuel Puddling in the intake and causing a Nitrous Backfire.
Old Jul 19, 2007 | 12:36 PM
im on a dry shot, so the backfire shouldn't happen, I would want to spray at 2k for when im launching.
Old Jul 19, 2007 | 01:26 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
That would explain why, lol
Are u wanting the progressive controller for traction issues or what is the main reason?
Old Jul 19, 2007 | 01:30 PM
I would just like to be able to start spraying at a lower rpm and was wondering if spraying a little less would enable me to do so. I kind of figured i wouldn't be able to but i thought i would see anyway.
Old Jul 23, 2007 | 02:54 PM
TNTramair's Avatar
you can just change your activation Rpm in your Timing tuner to start spraying a little
earlier.
