How to control 2 stages
Old Jul 23, 2007 | 10:23 PM
ls1408cp's Avatar
Default How to control 2 stages
I am going to run a 100shot straight of the line then a 200shot after that on a delay or slightly progressed. I need a window switch on both and timing pulled on the 200shot. I also saw nxs maximiser 2 and it said it had a timing feature but I am not sure if its ls1 based. Also the maximiser said something about a lean cutoff when piggybacked with a FJO wideband. Any info on this part would be nice. I dont think their is a controller that can do it all but post up what you recommend... I know thw maximiser is expensive but after you buy everything seperate it adds up close to the same price. Also has anyone used the MSD timing twister to pull timing? I just think the timing tuner looks cheap.
heres a link to the maximiser2 controller
http://www.nitrousoutlet.com/catalog...product_id=342
Old Jul 23, 2007 | 10:42 PM
Robert56's Avatar
Do a search for threads started by me, i did an intro thread on a kit I run. i did it a little different from what you want to do, but you may get some insight. I have been running dual stge for a few years. You may want to consider making your 1st stg dry, then you can automaticlly pull timing in tune and not effect n/a timing and no need for an additional timing pull device, it keeps it mucho simple (write up in my personal web). If ya can't find the thread I post a link later.
Robert
Old Jul 23, 2007 | 11:07 PM
ls1408cp's Avatar
I dont have a maf sensor. The first stage will be comming out of a 4inch pipe ram air setup followed by a 105mm tb. I also have a 98 if that matters I have never been into the dry kits
