wiring issues..checked diagram..no spray
Old Jul 27, 2007 | 11:56 PM
BawlsZ28's Avatar
Default wiring issues..checked diagram..no spray
Okay,
I have triple checked my wiring diagram from COld Fusion for the dry/wet kit. the relay clicks, but the nos soleniod does nothing. I even moved my ground to a diff spot and same thing. I tried wiring it up diff ways from other kits and same thing. Any ideas???
2000 silverdo 5.3
I am using their kit directly-no FPSS, only a dry solenoid, relay, act. switch, and WOT switch. Any help would be greatly appreciated. I did check the sticky as well.
Old Jul 28, 2007 | 12:01 AM
SSDriver's Avatar
lol, did you put in a fuse
Old Jul 28, 2007 | 12:09 AM
BawlsZ28's Avatar
Yes, where it is directly off the + battery terminal. And yes, it's not blown!
Old Jul 28, 2007 | 08:54 AM
NXRICKY's Avatar
Closed ex-Sponsor Account
IF your relay is clicking that part of your wiring is fine. Testlight large input wire see if its HOT, then check the large output wire to the noids, see if its hot when relay is clicked.. IF they both hot, then your noids wither have a bad ground OR their fried.
Old Jul 28, 2007 | 09:32 AM
BawlsZ28's Avatar
Thanks so much for your help, i'll check that and see what happens.
Old Jul 28, 2007 | 02:16 PM
BawlsZ28's Avatar
Solenoid is bad even though it is brand new!!! THx for all the help.
Old Jul 28, 2007 | 09:40 PM
NXRICKY's Avatar
**** happens. test the noid, hot and ground to battery. No click yeppers noids junk.
