heads and cam what all do i need?
Old May 19, 2003 | 02:50 PM
nc z28's Avatar
Default heads and cam what all do i need?
i have tea stage 1.5 5.3l heads and a tr 224 112 cam. my car is an m6. it dynod at 428 rwhp and 400 rwtq. i want to run a mild 75-100 shot. ive been told to get either tnt or nx kits. what else will be required along w/ the kits?(pumps,injectors,etc. if needed) i want it to be as safe as possible. please help!!
Old May 19, 2003 | 06:09 PM
nc z28's Avatar
Default Re: heads and cam what all do i need?
anyone?
Old May 19, 2003 | 07:54 PM
Tim 98z's Avatar
Um you can read my post a fiew down from yours. Almost the same question. But i cant help you much since i havent sprayed mine yet.
Old May 22, 2003 | 11:27 PM
14u2nv's Avatar
I too have H/C and want to juice it. I have been told by several vendors on this site the folowing:
-swap plugs to NGk-TR6 gapped @ .035
-get a walboro 255, 340, or dual in tank fuel pump/s
-window switch, wide open throttle switch, fuel pressure safety switch, bottle heater, and purge
You don't need to upgrade injectors with a wet system only a dry. Racetronix has a plug'n'play intank fuel pump for 1998 f-bodies with metal tanks. They are coming out with one for 99-up w/ plastic tanks this spring(soon).
