Solenoid upgrade question
Old Jul 30, 2007 | 07:53 PM
a84stang's Avatar
Default Solenoid upgrade question
I know its a mustang, but you guys seem to be on top of your nitrous stuff over here. My set up is an NX hitman plate kit, I was wondering when upgrading my noids will I have to change the current tune or will it not matter because the jets are still remaining the same ? Also any suggestions on which NX noids to purchase ? Thanks in advance.
Old Jul 30, 2007 | 09:11 PM
socmguy's Avatar
Restricted User
I'm sure as long as you're still using the same jets you should be fine and won't have to change anything.
Old Jul 30, 2007 | 10:28 PM
donkey mule's Avatar
If you have a wideband I would monitor it just to double check. I wouldnt think timing would be an issue.
Old Jul 31, 2007 | 12:07 AM
Gimp98TNT's Avatar
Only reason your tune would need to be changed if your old niods were too small, and not flowing enough for the jet size you were running.
Next set of Niods im buying are NX lightning niods.
Old Jul 31, 2007 | 03:53 PM
a84stang's Avatar
thanks
Old Jul 31, 2007 | 04:18 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
How much are you planning on spraying....the standard NX Lightning solenoids will support 300hp
Nitrous .093
http://www.nitrousoutlet.com/catalog...roduct_id=1187
Fuel .187
http://www.nitrousoutlet.com/catalog...roduct_id=1183
I might be wrong but I think the Hitman comes with the .187 fuel solenoid.
Changing the solenoids will not affect the tune, unless there was a problem before.
Old Aug 1, 2007 | 03:36 PM
a84stang's Avatar
basically my only problem is my purge solenoid not opening under pressure greater than 1000 psi. I just figured upgrading all noids while I was at it. Only sprayin a 150 shot
