11.1 cr and 150 wet shot???
Old May 19, 2003 | 10:22 PM
BIG PD's Avatar
Default 11.1 cr and 150 wet shot???
welp i'm trying to figure out if i will be able to do a 150 tnt wet shot on my motor with 11.1 compression. if i can i'll get the 5.3 heads...if i can't i'll get the 5.7 heads. no biggie. thanks
Old May 20, 2003 | 07:57 AM
chadtn's Avatar
Default Re: 11.1 cr and 150 wet shot???
It will be fine. Go for it.
Chad
Old May 20, 2003 | 08:15 AM
Big Mike's Avatar
I'm on a 12:5:1 with a 200 shot. As long as you have enough fuel!!! You'll be fine!
Old May 21, 2003 | 01:06 AM
Speeds8erM-1's Avatar
Compression and nitrous really dosent matter as long as you dont go lean and can keep the heads on the block.
