Bottle install
I'm close to starting my installation and I'm trying to figure out the best way to install my bottle. You can see from the pic that it's intended to look as good as I hope it works, but the installation location is problematic to say the least. As I expected, I don't see any way to install the bottle with bolts as is without removing the gas tank to gain access under the car. My other idea is to fabricate a plate with preinstalled bots and weld it in place. Then I set the bracket on top of the plate and install the nuts. Anyone have a better idea?
can that panel the bottle is sitting on be removed from above the fuel tank???come up from the bottom of that panel with a plate with just the bolts sticking thru the carpet...
i ask because i ain't f-body qualified since i own a gto...
Originally Posted by Z O SICK
Where did you get that bottle bracket? It looks pimp!
Originally Posted by jwitt2
make sure they are self tapping screws..
i removed my tank yesterday to install the holley fuel pump as i'll be going on gas soon as well, with the tank in you have humps under the carpet which are double walled, they have two layers, then dips are mostly single walled, trust me, i cut a big hole in the place over my fuel tank to finally change the pump, but anyway, i'd suggest rivetting a piece of aluminum or a fix a piece of thin wood under the carpet to hold the bottle in place, just my thoughts....
I just pulled the carpet back and welded four bolts to the floorboard head first. Then I used a razor blade to make a small X in the carpet where each bolt came through then bolted the base of the mount to the bolts. I use a 15 pound bottle on the same mount you have and it hasn't given me any problems on the strip or on the street and it's been in the car for five years now.
Originally Posted by Toecutter
That is not NHRA or IHRA legal. If you ever decide to go to a track, it will not pass tech. You must use a bolt, nuts and washers. In an accident, and self-taps only, the bottle will come off and hit someone upside the head
Good point cutter.
